Old 29-Feb-2016, 6:24 PM   #13
Blackbeen
Could you tell me if the Antennas Direct Juice AC adapter is 12vdc 200ma? I have a cpa-19 pre-amplifier & I believe the adapter died, I live in a Apt & don't have easy access to the pre-amp so if the issue is with that it will have to wait until I move to a house later this year. I was wondering if I could use the Juice AC inserter in the short run as Antennas Direct is sending me one in replacement, I was considering grabbing a 12vdc 200ma adapter off ebay or somewhere else & splicing it in but if I could use the Juice one I won't bother.
After taking a second look, I still think the 7698 is right for you. Maybe ADTech will stop by and double check my analysis. He's pretty sharp, and suggests the right tool for the job no matter who makes it.
Some people have trouble folding out the VHF elements in the correct order. The VHF section is a log-periodic design; the elements should alternate as indicated in the instructions.
Channel Master 7778, has an FM filter
Antennas Direct Juice, resistant to overload, has 4G LTE filter but no FM filter, FM filter can be added if needed
other preamps available
Channel Master 7777, high gain, for weak signal areas only, easily overloaded, maybe for you?
RCA TVPRAMP1R, inexpensive, has a history of quality control problems, otherwise OK
Winegard LNA200, was good until they redesigned it to meet price point of big box stores
Blackbeen is offline   Reply With Quote
