Old 28-Feb-2016, 7:16 PM   #6
Originally Posted by Waaafles
My wife would like to watch the Oscars this weekend. It is carried by CTV (CKCO-TV) but is very fuzzy. Perhaps I will look into making an antenna to pick this one up.
CFPL is 55 dB stronger than CKCO. They are both VHF-High channels and in the same direction. CFPL-FM is 77.4 db stronger than CKCO, so an FM filter should be used in the antenna coax to make CFPL-FM weaker. Even at that, CFPL (TV) might overpower the CKCO signal, but why don't you try it.
http://www.fmfool.com/modeling/tmp/1...f/Radar-FM.png
A custom bandstop filter by Tin Lee Electronics could make CFPL on real channel 10 a lot weaker and give a better chance to receive CKCO on real channel 13, but they are expensive.
http://www.tinlee.com/index.php
Years ago, Channel Master used to make a channel 13 antenna combiner called the Jointenna, but they are no longer available.
http://www.channelmaster.com/JOIN_TE..._p/cm-0583.htm
There is a new company based in Slovakia, jan_jenca, that has been an eBay member since Jan 30, 2013. They make custom antenna combiners for a reasonable price. This is an example of a UHF combiner that they make; they can also make one for VHF:
http://www.ebay.com/itm/Selective-combiner-for-2-antennas-Selective-channel-combiner-UHF-combiner-/121884348649?hash=item1c60df90e9:gGAAAOSw~bFWNinN
AVS thread on the topic:
http://www.avsforum.com/forum/25-hdt...xchange-4.html
http://www.avsforum.com/forum/25-hdt...xchange-5.html
