Old 26-Feb-2016, 12:34 PM   #6
shoman94
Originally Posted by Huntington View Post
Rabbit and Shoman,
Thank you for the quick and informative replies. I was just wondering if anyone could comment on the advantages and disadvantages or the traditional Yagi type antenna like the Winegard HD7698P as compared to a bowtie type antenna like the Antennas Direct DB4e.
I know the bowtie is smaller, but how do they compare on gain/beamwidth. Correct me if I'm wrong, but for my situation I think I need as much antenna gain as possible. As for the DB4e, they also offer an 8 element bowtie with over 17 dB of gain. Can that only help my situation, or is there any downside to this?
Thanks.
I'll link the PDF's for each antenna so you can make an informed decision.
IMO as far as gain they are both similar but the DB4e has a much wider beam and more pull from the back side which I think could help pull in some extra channels in your report.
HD7698p
DB4e
DB8e
The DB8e has even more gain but a narrower main beam with a lobe on each side of the main beam. It is adjustable and that could be used to your advantage but will require trial and error as well. I guess the biggest thing is what channels you want should help you decide which antenna could work for you.
I don't know specifics of design differences but if performance was the same I'd surely prefer the smaller package for aesthetics purposes and ease of installation.
