Old 25-Feb-2016, 10:49 PM   #3
shoman94
You could get all your channels except ABC with a good UHF antenna pointed at 273 degrees magnetic. You could also look at the Antennas Direct DB4e to take care of your UHF stations in a lot smaller package.
ABC is VHF which you could get with the add on VHF dipole retrofit kit also pointed in the same direction as the UHF antenna.
The antennas can be purchased direct or also at Amazon.
Antennas Direct VHF Retrofit kit.
You'll also need a mount system which best suits your needs and places it in an area with the least obstacles.
I suspect you'll need a preamp such as the CM-7778 or Antennas Direct "Juice". Have you done an FMfool report to see if you have any radio stations next to you?
