Old 25-Feb-2016, 3:33 PM   #13
Reception issues due to storms usually fall into two categories: 1) Lightning-induced impulse noise, usually on VHF for up to moderate or even long distances and 2) Tree-induced multipath caused by the signal getting shredded when going through moving trees.
As for the train, two very similar causes: 1) Electrical noise from the diesel-electric generators and the electrical drive motors, primarily on VHF and while the engine(s) are closest and 2) multi-path caused by signal reflections and blockages from the moving train.
So things you would think aren't necessarily big deals do truly affect signal strength.
Most often, it's not signal strength that's being affected, it's the quality of the signal that gets degraded.
