Old 24-Feb-2016, 2:22 PM   #6
bighop
Thank you for this info, its a big help.
I bought that antenna after a phone call to Antenna Direct. I told them I was putting it in my attic, and thats what they recommended.
I have a combiner on the antenna, because of the VHF accessory antenna I bought from Antenna direct.
There is no room to place a VHF above the UHF antenna, can I place it on a separate mast near the UFH antenna?
Also, this sounds really dumb, I used my iPhone's compass to set the direction. I set the UHF to about 220 degrees. What do you mean by setting to true north?
Is the signal straight tester something expensive?
Thanks again for the info.
bighop is offline   Reply With Quote
