rickbb,
Yes, I am definitely currently pointing this antenna in the "wrong direction". However, I am getting "decent" reception. Some desired uhf signals are not being received. It really did cause the CBS signal to come in stronger. I guess I had not really found a good position to pull in that signal. All in all this gives me a good feeling that the corrected/finished installation will give a decent, reliable, and stable reception of the desired signals.
ADTech,
Yes, I will point the Yagi end at the aimpoint for my desired signals. That's about 44-45 magnetic.
shoman94,
Appreciate the insight about the Juice model having an LTE filter, and being overload resistant. That is a good tip to aim first, then hook up pre-amp. Where in line would an FM filter be placed? Between the antenna and the pre-amp? Is there any reason to install an FM filter. My FM report showed strongest signals at -31 dbm?
Thanks all!
Reason: Bad link
