Old 23-Feb-2016, 3:11 PM   #6
rickbb
If you are going to try a pre-amp you should get a low to mid power model as you have many strong signals that can overload your tuners.
As for pointing the antenna 180 degrees off, are you certain about which is the front of the antenna? It's a common misconception to point LPDA style antennas like an arrow with the tip of the arrow aimed at the tower.
That's backwards, you point what looks like the back of the arrow in the direction of the tower(s).
Look here and scroll down to the Log-Periodic Dipole Array antennas, (which is what you have).
http://www.hdtvprimer.com/ANTENNAS/types.html
