Thread: Attic or Not
Old 23-Feb-2016, 1:52 AM   #44
Frustrated Cable Cutter
Thanks for checking ADTech, I have a klien cable tester and will check the continuity of the braid on my cable, I really should have done that to begin with. Do you have any input into the design of your amps? If so a led on the amp showing power from the inserter would be a most welcome addition.
Frustrated Cable Cutter is offline   Reply With Quote
