Thread: Elusive Channel
Old 22-Feb-2016, 10:59 PM   #6
cnick
Thanks again for the replies!
I was playing with the positioning today and was able to pull in XETV at full power. The antenna is actually tucked behind, and pointing through, a stucco wall! So this leads me to believe that the attic install may indeed work if I was able to get it pointed in the right direction?
If no go on the attic, the wife just let me know that the antenna "looks ridiculous" so I am going to try and hide it on the backside of the house. The obvious problem with that is that I need a mast to be able to clear the roof ridge. That being said, is there a minimum clearance I need to have above the ridge or do I just need a line of sight to the towers? There are a couple of palm trees in the way about 500 ft out..
Thanks again!
cnick is offline   Reply With Quote
