This is incorrect. XETV operates on UHF 23. The analog 6 signal was shut off several years ago, but the proprietor of this site still hasn't deleted the out-of-date data from his database. See
http://forum.tvfool.com/showthread.php?t=13354
FYI, the SKY is a bi-directional antenna, it has no ability to focus in one direction while rejecting from the opposite.
Obviously I need to mount it and point it correctly
Yes, this is what you need to do. You've simply plopped the antenna down and it happened to land in a dead spot for that channel.
Several words of advice: Do NOT drill any holes until you've found a suitable location where everything desired works. Use only temporary mounting provisions while testing.
