So let me understand this...... You had to point your antenna 180 degrees opposite of Real Channel 9 to get a good signal? I'm not so sure that antenna is the right option for you. Can you return it?
Your TVFOOL report looks great. Wish mine was that nice....lol
I think your on the right track with moving the antenna to a better line of site. IMO a better antenna such as the Antennas Direct C2V might be a better option. It could be tested in your current location and without a preamp but if those trees are going to fill up in the summer I'd strongly recommend moving the antenna to a better LOS option either now or when summer comes. I'm not sure that inline surge protector is helping you out. I personally don't have experience with one but I have never seen to recommended to be used. The COAX should be grounded before it comes in the house. You could also add a ground wire from your splitter inside to a ground in your electrical panel. You internet COAX may already be connected that way.
