Thread: Attic or Not
Old 19-Feb-2016, 2:20 AM   #42
Frustrated Cable Cutter
ADTech, Your office received it on the 15th, our included correspondence was sent to the attention of Angie Greenway.
Unfortunately, I didn't take the time to check to see which channels were available after adding the pre amp. I installed the juice at the antenna using the 3ft cable that was included with the kit. I have approx. 45ft of RG6 coax running directly to my TV. I installed the inserter just before the connector on the back of my set. At the time of testing I didn't have the splitter installed. I contacted AD tech support at the time of installation and the only advise that I received at the time was to obtain an RMA and send it back. After further searching on-line I found a post at Dennys TV that recommended testing the output of the inserter with a VOM. I wish I would have ran into that post before I sent it back. The post went on to say that the inserter uses the braided shield as a ground for the 12 VDC power supply. It is possible that the braid isn't terminated properly on one end or the other. I will definitely check that possibility before I try this again.
Frustrated Cable Cutter is offline   Reply With Quote
