Old 17-Feb-2016, 5:26 PM   #14
manfjourde
If this is what you want to do, I think it would work:
Code:
                                                 coax 100ft > TV
42XG > coax 10ft > grounding > 3410 > splitter >            coax 50ft > TV
                     block                      \          /
                                                 splitter >
                                                            coax 50ft > TV
The 3412 contains a splitter inside the case, so a 3412 plus one splitter gives the same result as a 3410 and two splitters.
That is exactly what I want to do, the end of the 50 foot runs has a splitter to split the signal between the two floors. I couldn't make a diagram like you - it didn't format correctly but what you did is exactly what I am thinking.
manfjourde is offline   Reply With Quote
