Old 17-Feb-2016, 3:04 AM   #12
I see no advantage to using the 3410 instead of the 3412 as in the diagram in post #7. Using the 3410 would require adding another 2-way splitter and you would end up with the same signal strengths at the TVs. The 3412 already has an internal splitter to give 2 outputs; it is equivalent to a 3410 and a splitter.
Will a CM 3410 suffice? Upon investigating the setup, the cable splits and goes toward the 50ft TVs and the 100ft. I think I could get away with one output, or I could eliminate the current split and use the amp as the splitter and amp. Would it be better to do that instead of splitting after the amp?
That doesn't seem to agree with your original description:
I currently have an Antennas Direct 42XG, about 15 feet off the ground. I have about 10 feet, the signal splits and goes 3 different ways. The two TVs are fine at the moment, both about 50 feet from the split, signal could be better on some channels but most come through. The other TV is about 50 feet further.
I don't understand what you want to do; can you show me a diagram?
