Old 16-Feb-2016, 5:44 PM   #11
manfjourde
No, not exactly.
Code:
                                                          100 ft
Ant > preamp > coax > grounding > coax > power  > splitter        50 ft
                       block            inserter         \       /
                                                          splitter
        50 ft
Thanks for the reminder, when I set it up initially I grounded the antenna as well as the coax.
Will a CM 3410 suffice? Upon investigating the setup, the cable splits and goes toward the 50ft TVs and the 100ft. I think I could get away with one output, or I could eliminate the current split and use the amp as the splitter and amp. Would it be better to do that instead of splitting after the amp?
Currently
Antenna > coax > splitter (goes 100, 50 and splits at the 50 another 5ft to separate TVs
manfjourde is offline   Reply With Quote
