I think your chances of getting Fox are not that good. If you click on the station in the list you can see the terrain profile that shows you are literally down in a hole from the transmitter.
You're in a radio shadow behind the various mountains between you and the tower.
It is only 7 miles and a good quality signal, but you're still in a RF shadow. You will need the antenna up as high as you can get it. You might pickup enough of a signal bounce or find a sweet spot in some multipath. But you will need a bit of luck and lots of trial and error to find it.
I think it's not so much which antenna as it is where.
