It sounds like you need to optimize the location of the antenna. It's probably in a poor signal location.
Try to get it up in the air, especially out from behind common impediments like buildings and trees as much as you can.
Your C2V, as noted by tomfoolery, has no need for the VHF module in Boston, so remove it and connect directly to the back of the C2's loop element.
The C2 has a 70° horizontal beam width, plenty enough to cover all your UHF stations. It's not terribly picky about aiming, but that wide pickup pattern can make getting its location more important so as to minimize unwanted reflections.
