Old 5-Feb-2016, 9:20 PM   #11
Enochsmoken
[QUOTE=rabbit73;54478]You don't know for sure if you have no way to measure the signal strength, and neither do we because RCA doesn't give the antenna gain figures.
There is a simple test you can do. Insert a variable attenuator between the antenna and the preamp input to see if the system behaves any better.
Where do I place the attenuator, before or after the power input of pre amplifier?
Enochsmoken is offline   Reply With Quote
