Old 21-Jan-2011, 6:53 AM   #11
John Candle
Tv Antennas and Reception
If you will like to bump the received signal strength up more then it's time to raise the antenna height. Go to the >>StartMAPS<< part of tvfool put in your address , select the current plus pending stations , start with the antenna at 40 feet high and raise the antenna 10 feet at a time , you will see that the NM(dB) figures really start to improve at 60 feet and as the antenna goes higher up to 100 feet more tv stations become LOS Line Of Sight.
