Old 5-Feb-2016, 3:33 AM   #7
Flint Ridge
Junior Member Wannabe
Thanks Travis798, now we have something to try to work out. Given your location, knowing the weather headed your way is wise.
So, stations @ 210 degrees.
NBC KFOR - Real Ch 27 - UHF - 2 Edge @ 2.8 NM(db) - Red Zone - at bottom
CBS KWTV - Real Ch 39 - UHF - 2 Edge @ 0.5 NM(db) - Red Zone - at bottom
FOX KOKH - Real Ch 24 - UHF - 2 Edge @ -10 NM(db) - Grey Zone - Extreme Measures
I'm sure you know this but it is FLAT in you area. Have you tried looking at bumping it to 30' 40' 50' on your TVFool report? Curious what happens to the signal strength.
Is it clear in that direction? Trees/buildings etc that might block your signal?
Certainly looks like it is possible to get those. Recommendations from experts will likely come along - just an amateur here.
Flint Ridge is offline   Reply With Quote
