Old 2-Feb-2016, 2:22 PM   #7
Too bad I need to buy the antenna first, I'd hate to waist the money.
So do I, but there is no way we can give you a guarantee.
What do professional installers use for tools or test equipment to determine the best system for your home
A professional installer would look at your tvfool report and be familiar with the signals in your area. He would pick the best antenna for those signals in the best location available. So, far that's what we have done.
But, he can do something we can't do, which is measure the signal strength of your signals with a signal level meter while trying different locations in your attic. His meter might also be capable of measuring the signal quality which is just as important as signal strength with digital signals. Signal quality is defined by SNR (Signal to Noise Ratio) and errors in the digital stream of information.
This is what my signal level meters look like:
My Sony TV has a diagnostics screen that gives relative signal strength, SNR, and uncorrected errors.
bad signal with SNR below 15 dB and errors:
good signal:
I have also used a converter box with dual signal bars for signal quality and signal strength:
If you are into computers, you can use the signal monitor of the SiliconDust HDHR.
Hopefully, your TV has a signal strength indicator that can help you find the best location in your attic for the antenna. If it does, you will soon find out how weak a signal can be and still give satisfactory reception.
What make and model is your TV?
I gave you the short answer in my first post to you because that is all the time I had then. The other guys filled in the blanks as I knew they would.
This was my long answer.
Please let us know the results of your tests on this same thread.
