Old 29-Jan-2016, 12:11 AM   #47
shoman94
It depends on the design goal. Stacking two double loops vertically would indeed increase the peak boresite gain by about the same as stacking them horizontally while maintaining the ~70° HPBW instead of halving the HPBW as does the implemented design.. However, you would have to have a much longer mast to accommodate the vertical stack and this particular products was designed with retail (B&M) store shelf space in mind. It would also make assembly more complicated.
SO are you saying that if I kept the UHF elements the same orientation but stacked vertically I would end up with the same gain but keep the 70 degree HPBW? I think that would suit me based on my report!
Looking at the installation manual I think I can stack the loop elements and have the combiner bar connections on the loops facing each other and maybe this would still allow the combiner bars fit right up?
