Old 28-Jan-2016, 7:52 PM   #11
After taking a second look, I still think the 7698 is right for you. Maybe ADTech will stop by and double check my analysis. He's pretty sharp, and suggests the right tool for the job no matter who makes it.
Some people have trouble folding out the VHF elements in the correct order. The VHF section is a log-periodic design; the elements should alternate as indicated in the instructions.
Also what is your suggestion for an amp.
Channel Master 7778, has an FM filter
Antennas Direct Juice, resistant to overload, has 4G LTE filter but no FM filter, FM filter can be added if needed
other preamps available
Channel Master 7777, high gain, for weak signal areas only, easily overloaded, maybe for you?
RCA TVPRAMP1R, inexpensive, has a history of quality control problems, otherwise OK
Winegard LNA200, was good until they redesigned it to meet price point of big box stores
