Old 20-Jan-2011, 9:13 PM   #4
jj-chlt
Thanks for the suggestions GroundUrMast and John Candle. Looking at specs for the DB4 and 4221HD, the DB4 seems to have a wider beam width while some have indicated the 4221 has a little bit better gain. Since the stations in my area seem to generally be in two clusters at 307 deg. mag. and 25-40 deg. mag. I probably need to go with the wider reach of the DB4.
Regarding John Candle's positioning suggestions, I am afraid I don't understand. Would it not be better to aim at the weaker, and farther away, NBC and CBS affiliates @306/307 deg. mag. since the stations to the NE are stronger and within 10 miles?
jj-chlt is offline   Reply With Quote
