Old 27-Jan-2016, 1:20 AM   #6
I will make sure I use a pre-amp and a custom high pass attenuator.
Please don't call it an attenuator; that is a different device. It will attenuate channel 8 making it weaker, but you must call it a high pass filter when you talk to a Tin Lee Electronics filter engineer and send him your tvfool report by email.
http://www.tinlee.com/contactUs.php
The filter will probably cost more than $100, so you want to get it right. We don't see any other alternative to the custom filter, unless you are willing to settle for fewer channels.
It is important to ground the coax with a grounding block to reject your strong local interference, otherwise it will get directly into the TV cabinet.
