Thread: Long range help
Old 27-Jan-2016, 1:48 AM   #8
The C4 has less gain than the DB8e and would make WFTV ABC 39 even more unreliable, but you are welcome to try it.
https://www.antennasdirect.com/cmss_...-sellsheet.pdf
The DB8e, with both panels aimed in the same direction, is the current champion when it comes to UHF gain.
https://www.antennasdirect.com/cmss_files/attachmentlibrary/Technical%20Data%20PDF's/DB8E-TDS.pdf
Would the 91XG be acceptable?
https://www.antennasdirect.com/cmss_files/attachmentlibrary/Technical%20Data%20PDF's/91XG-TDS.pdf
The tvfool reports for 2Edge signals are less accurate, so it is difficult to predict results with the accuracy you would like. With so many factors involved it isn't possible to make a guarantee.
You must expect some experimentation will be necessary. It might boil down to making a choice between reliable reception and appearance.
