Excellent, thanks for the info guys. I will make sure I use a pre-amp and a custom high pass attenuator. For experimentation purposes, is it okay to hook up to the tv without the attenuator/pre-amp, or will it probably blow the tuner?
Also, I know many people don't recommend the 7777 pre amp, but am I right to assume that in my situation with most of the channels being pretty weak this would be a good choice?
Thanks!
Reason: 2nd paragraph
