Old 26-Jan-2016, 12:10 PM   #2
Here is the repaired TVFool link: http://www.tvfool.com/?option=com_wr...51344010e4a4d6
FMFool does not provide clickable links, you must save it as an image, then post that image.
The HD8200 is not a suitable choice as there are no low VHF stations anywhere in your area. You can use one, but there's a lot of unused metal there.
You will probably need to attenuate both the immediate analog channel 8 as well as FM by 25+ dB to keep them out of the system. www.tinlee.com over in Toronto can custom make one for you. All you'd need is a low-pass filter that takes out everything channel 8 and below.
1. For Ottawa, select either a large high VHF/UHF combo or a separate UHF and a separate high-VHF antenna. You will need a suitable preamplifier.
2. Your idea is on track.
3. Unlikely to work. Repeat step one advice instead.
