Old 26-Jan-2016, 1:34 AM   #34
bebo189
Sorry, it's taken me so long to respond.
Do you have AC power for the 3412 in the attic?
Yes, I have the 3412 plugged into an outlet in the attic using the AC adapter that came with the 3412. The AC adapter is connected to the unit via a coax cable.
I went ahead and used the instructions you posted to get the signal strength/signal quality readings for each channel on the LG 42LD550 (2nd Story TV). Here they are:
Reminder: Green is channels I get on the 2nd Floor TV but not on the 1st Floor TV. Bolded Channels are the ones that I actually WANT to get on both TVs.
I am not sure what the difference is between "Signal Strength" and "Signal Qualtiy" as called out on my LG 42LD550 TV.
Also, the weird thing to me is that is that the main channels that I want to get on the 1st Floor TV, but only get on the 2nd Floor TV (WSOC-TV, WTVI-HD, WTVI-MV, WTVI-Ct) all have "Signal Strengths" on the 2nd Floor TV of 89% or higher. In fact, there are stations that I got on both TVs, for which the signal strength on the 2nd Floor TV is lower than 89%. Doesn't really make any sense to me.
Also, can you confirm that "front" and "back" of antenna is as I think in the picture below?
bebo189 is offline   Reply With Quote
