Not getting all the channels
I recently put up a RCA TV antenna (model number ANT3036WR) but I couldn’t get all the stations I wanted. All stations are approximately 30 miles away. I live in a wooded area. The antenna is about 30 feet off the ground.
The antenna is pointing north towards the stations. At first I would only pick up the weak power stations. The following I don’t understand, the weak stations 12.6 and 30kW, come in great. The more powerful ones 90, 813, and 1000kW will not come in.
I then installed a channel master 7777 pre-amp. When I auto program, my tv finds the other higher power stations but they barely come in.
Help please.
