Moved the Juice and FM traps on the mast. FM traps are inside a weather tight box. I did move the VHF dipole from being clipped to the upper reflector to just under it and attached it to the mast so I can aim it. Now I can't get a lock on channel 10 anymore but I gained channel 11. I think the reflector was helping with that VHF channel when it was clipped to the reflector.
@ADTECH; I was wondering if you could provide me with a couple things....
What would the gain graph look like if I removed the reflectors or even just one reflector?
What would the gain graph look like if I rotated the C4V 90 degrees so they were aligned vertically vs horizontal?
Thanks!
