Old 23-Jan-2016, 3:50 AM   #15
hkinkade
Thanks gang, I have some ideas to check out. I'll try again, if it isn't working I can turn the inverters on the solar system off. at least this should eliminate the noise source as a potential source of the problem. Also, I took the channel view 0747 out of the circuit and lost every channel! I actually think it is a power supply and antenna amplifier in one. It doesn't appear to be soley a power supply (see attachment). Anyway it helps the UHF signal!
hkinkade is offline   Reply With Quote
