Old 20-Jan-2011, 4:56 PM   #6
egarding the one i cannot get it happens to be 62.1(wwj) and i don't understand why i don't get it when i do get 20.1(wmyd). according to the analysis results it would appear that they are potentially in the same building or very close neighbors anyways.
WWJ shares the same tower with WMYD and three other stations.
It sounds like your current antenna, whatever it actually is, is either in a localized "dead spot" for WWJ or there is a frequency-selective reflection that is causing multi-path on that one channel that is severe enough that your tuner cannot correct it. Attics are more prone to this effect than would be an outdoor antenna. The solution is to move the antenna to a different spot and try again. Repeat until either you're successful or you've exhausted all choices.
