ADTech:
1) Confirmed that I did NOT reverse the UHF / VHF connections (I checked twice)
2) I'll remove the power supply. It appears way in the past I mistakenly thought this was a signal amp, day??? I returned the Clearstream 2v. any suggestions on what antenna I should buy in preference over the 2V or would you stick with the 2V
3) Solar Panel interference, is this while they are producing power or strickly reflective?
