Old 21-Jan-2016, 3:15 AM   #31
Code:
                     50' > F81 > 20' > F81 > 6' > 2nd Fl
4221 > 50ft > 3412 >
                     50' > F81 > 60' > F81 > 25' >1st Fl
50 + 20 + 6 = 76 ft
50 + 60 + 25 = 135 ft
difference of 59 ft; about 3 dB for UHF,
approx. the same as a 2-way splitter loss
So if you inserted a 2-way splitter in the 2nd floor line after the 3412, the 2 TVs should be getting about the same signal strength. If not, there is another loss that exists in the 1st Floor line.
Also, is it possible that the 25 feet of coax cable that I run through the wall on the 1st floor to the TV would degrade the signal if it weren't 75 ohm quad shielded? I read somewhere that this was important. I bought this years ago, and I'm not sure if it is 75 ohm quad shielded or not.
The attenuation loss is about the same for regular coax as it is for quad. The quad has an extra layer of shield to reduce pickup of interference; you don't need it for most applications.
Do you have AC power for the 3412 in the attic?
Vizio M552I-B2 (1st floor TV)
LG 42LD550 (2nd floor TV)
LG 42LD550
http://www.lg.com/us/support-product/lg-42LD550
When selecting DTV or Cable DTV input signal in Manual Tuning, you can view the on-screen signal strength monitor to see the quality of the signal being received.
I'm having trouble downloading your Google doc of channels. I think I would need to log on before it would allow my me to download it; I have had this trouble before.
