Old 20-Jan-2016, 9:36 PM   #29
bebo189
Which direction did you pick for the 4221, 260 or 115?
I tried 260 first, then 115 (current direction and the setup used to pickup # of channels listed in my previous post).
Where is the 3412 located, near the antenna or further downstream?
3412 is right off of the antenna (maybe 6 feet of cable away at most).
Tell us how long the cable runs are starting at the antenna, then down to the splitter or 3412, then to each TV. Is it like this?
Code:
                           coax 20 ft > 2nd floor TV
4221 > coax 6 ft > 3412 >
                           coax 60 ft > 1st floor TV
Very similar, I'd say it's closer to this:
Code:
                           coax 50 ft > cable extension adapter male-to-male (in junction box) > coax 20 ft (guess) > 2nd floor coax wall jack > coax 6 ft> 2nd floor TV
                           coax 50 ft > cable extension adapter male-to-male (in junction box) > coax 60 ft (guess) > 1st floor coax wall jack> coax 25 ft (through wall) > 1st floor TV
Note: Up to this point, I have not had both 3412 outputs hooked up to both paths. I have been switching between paths where the coax 50 ft enters the junction box. After I verify that I can get all the channels I want on the downstairs TV, I plan to run the extra 50 ft coax and truly split the signal to both paths.
Also, is it possible that the 25 feet of coax cable that I run through the wall on the 1st floor to the TV would degrade the signal if it weren't 75 ohm quad shielded? I read somewhere that this was important. I bought this years ago, and I'm not sure if it is 75 ohm quad shielded or not.
Give us a list of channels at each TV; it does sound like the 3412 made an improvement.
I will pull the list when I get home for both TVs.
Do you have any way to measure the signal strength with one of your TVs?
I tried looking for this option on my 1st floor TV, but couldn't find anything after experimenting or googling the TV. My TVs are listed below. Maybe someone can help me locate a way to check it.
  • Vizio M552I-B2 (1st floor TV)
  • LG 42LD550 (2nd floor TV)
bebo189 is offline   Reply With Quote
