Thread
Attic or Not
19-Jan-2016, 11:55 PM
33
Frustrated Cable Cutter
Originally Posted by
Please be aware that the C4V has a different horizontal beamwidth pattern than the C2V. It
might
be a little more difficult to find an aim for the C4V that will cover 327 to 22 degrees.
The C2V claims 70 degrees
https://www.antennasdirect.com/clear...ntalplane.html
The C4V has a more narrow main lobe but 2 secondary lobes to make it a little wider
https://www.antennasdirect.com/cmss_...-sellsheet.pdf
page one shows a narrower (43) main lobe, but page 2 claims wide (70) coverage
The peculiar pattern with the two notches (nulls) that changes with frequency is the result of horizontal stacking. This pattern that has nulls is used in the Two-Antenna Trick on hdtvprimer.com with the phase reversed.
You can also see it in the pattern of the DB8e, which is two 4-bay antennas side-by-side.
https://www.antennasdirect.com/cmss_files/attachmentlibrary/Technical%20Data%20PDF's/DB8E-TDS.pdf
Thanks so much for your help rabbit73, being a layman I was affected by the advertising. I am definitely going to take your advice and get the c2v, it's cheaper too! I really have much to learn. Thanks again.
View Public Profile
Send a private message to Frustrated Cable Cutter
Find More Posts by Frustrated Cable Cutter
