What would installing the FM traps after the preamp do?
Typically, filtering is done prior to amplification to prevent the amplifier from creating distortion products with the amplifier itself.
However, in the case of the Juice, that thing is so tolerant of strong signals it will simply pass any FM signals though it (amplified, of course) without any discernible internally generated distortion. Unfortunately, that would then shift the risk of distortion to the active devices further down the chain such as tuners or any subsequent amps.
In your specific situation [emphasis added], you can readily install the tramps downstream of the Juice's power inserter and still keep any strong FM signals out of the downstream signal path. Since you're filtering post-amplification, you'll essentially need an extra trap in order to knock down the already-amplified FM signals.
