Thread: Attic or Not
Old 18-Jan-2016, 4:30 PM   #20
shoman94
Try the C2V in a temporary setup in the attic in several locations with the antenna aimed about 350 degrees true, 357 magnetic. Add a DB4e with preamp aimed at 4.1. Use an A/B switch to select which antenna needed. An alternative would be to connect the C2V to the TV antenna input and connect the DB4e to a separate tuner that connects to the TV aux input. Another alternative would be to combine both antennas with a custom Tin Lee AC7 combiner for NBC real channel 45.
http://www.tinlee.com/PDF/AC7-custom...kup%20Info.pdf
Don't you think that the channels are strong enough to pick up on the back side? I'm picking up channels half his channels strengths on the backside of my C4V. Using A/B and multiple tuners just seem over the top for his report IMO.
