Thread: Attic or Not
Old 18-Jan-2016, 4:36 AM   #18
shoman94
Originally Posted by Frustrated Cable Cutter View Post
Channel 4.x has local news for the area where I work. If I can't get it (even with heroic measures) it's not a show stopper.
Just to make sure I'm clear on your recommendations, which antenna is the most conservative (has the best chance of being successful).
The c2v, c4v, or db4e?
Would it hurt if I went ahead and put the pre amp in whether I need it or not?
Which vhf antenna should I get?
Thanks again for your help.
You only have one channel that is VHF but I think a UHF only antenna will still give you channel 12 (WJRT). Worth a shot before purchasing the add on VHF antenna. If you want channel 45 (WDIV) then I'd go with the DB4E and aim it at 143 MAG. This antenna has a bit more gain on channels above channel 24. The stations on the backside of the antenna aimed at 143 should be strong enough to be picked up on the backside. Depending on you cable length you might need a pre amp. I'd try without first. I ended up getting the best reliable signal for my situation with only a powered distribution splitter since I'm going to multiple TVs.
I think that is your best chance at getting all the channels you want between the 3 antennas.
If you have a BestBuy local to you, you could always try the other 2 first since they have a good return policy.
