Old 20-Jan-2011, 11:19 AM   #4
jevans
Originally Posted by John Candle View Post
I agree , you have Way Too Many Easy To Receive Digital Tv Stations. The digital transmissions are very strong. If the house is not wrapped with any type or kind metal such as but not limited to metal siding or stucko with stucko Wire. And if the house does not have a metal roof. And if the insulation in the house is not metal foil backed. And if the walls are not made out of poured concrete. I know it's a long list , but most people do not understand that metal blocks and reflects Tv signals. And that poured concrete walls block Tv signals. Any way the Tv signals are very strong so , indoor Tv antenna will receive many channels. http://forum.tvfool.com/showthread.php?t=233 , Here is how to point tv antennas http://www.kyes.com/antenna/pointing/pointing.html
Thanks for the info. My house is a townhouse that is all red brick. My TV in kitchen has the indoor antenna that is on the attached photo. Reception is great, sometimes. Many drop-outs at other times.
The main TV is in the basement. I never tried an indoor antenna there since it is below ground level.
Of course, Winegard recommended there top antenna (HD8200U) with a rotator.
I would like all three TV's to pull in as many stations as possible. I live alone so rotating would not be a problem.
Do you still think that indoor is the way to go? Even for the basement TV?
If roof is the way to go, which antenna would suffice?
jevans is offline   Reply With Quote
