Thread: Attic or Not
Old 17-Jan-2016, 4:10 PM   #12
shoman94
25.x, WEYI NBC & CW, NM 56.3 dB, 22 degrees
49.x, WAQP Ind, NM 54.8 dB, 329 degrees
66.x, WSMH Fox, NM 53.4 dB, 327 degrees
12.x, WJRT ABC, NM 41.4 dB, 330 degrees
46.x, WBSF CW & NBC, NM 35.3 dB, 1 degree
4.x, WDIV NBC, NM 6.3 dB, 136 degrees; you don't need that, you already have 2 NBCs
40.x, ? I don't see that; what is the callsign?
5.x, WNEM CBS, NM 32.2 dB, 1 degree
click on callsign to see networks
That often helps.
Try the C2V in a temporary setup in the attic in several locations with the antenna aimed about 350 degrees true, 357 magnetic. If that doesn't work, add a preamp like the Antenna Direct Juice or Channel Master 7778. The 7777 would probably be overloaded.
If that doesn't work, you will have to go outside and higher.
WLMB 40.X is not going to happen. He won't get 4.x with a C2V. If it's a must I still stand by my choice of the c4v with the vhf add on at best buy. A db4e would be another good choice but he'll need to add a vhf antenna also.
