Thread: Attic or Not
Old 15-Jan-2016, 9:25 PM   #4
Frustrated Cable Cutter
Thanks for the replies. I realize that an antenna in the attic is risky, but I was hoping to be able to make an educated decision based on the experience and wisdom of guys who've been there. Is there an antenna combination that I should try in the attic that if unsuccessful can be successfully relocated to a mast? Would a pre amp like the CM7777 be helpful? Has anyone successfully paired 2 DB4's in order to pick up signals from opposing antenna's without using a rotor?
https://www.antennasdirect.com/store...c2-250x250.jpg
Thanks again
Frustrated Cable Cutter is offline   Reply With Quote
