Tv Antennas and Reception
Splitters are 2 way , 3 way , 4 way or more. If it's 2 Tv's then use a 2 way splitter. I suggest direct the antenna at about 55 degrees magnetic compass. Reason: to get the strong stations of the 307 magnetic compass direction to be received on the back side of the antenna. Or you can do it this way , direct the antenna at about 297 degrees magnetic compass. And you will get some strong channels from about 50 degrees magnetic compass on the back side of the antenna.
