Thread: Attic or Not
Old 15-Jan-2016, 12:36 AM   #1
Frustrated Cable Cutter
Attic or Not
I am earnestly trying to cut the cable and at the same time trying to learn about the intricacies of OTA antennas and signal capture. This forum and signal emulation tools have been invaluable. Thanks for your help and expertise. My first attempt was to try a Winegard Flatwave amped Antenna Model FL5500A. I was hoping to be able to place the antenna on top of the built in cabinet that I have my TV in. This would have placed it around 10ft AGL. Reception was spotty at best. I tried moving it around the room looking for a better location. Reception was good as long as the Antenna was perfectly aligned and in a narrow area of the living room, less than perfect results. I am wondering what your opinion would be concerning locating an antenna in the Attic. I have limited room (hip roof), but am loathe to put up a mast. Thanks again for your help.
Here is the link to my report: http://www.tvfool.com/?option=com_wr...5134743d304345
I have a single layer of asphalt shingles over 1 x lathe.
Frustrated Cable Cutter is offline   Reply With Quote
