Old 14-Jan-2016, 7:58 PM   #13
My neighbor is having trouble with WNBC (channel 4‑1 (28)) I'm hoping to be able to do something that will enable me to receive this channel.
That is an important channel, but one of your weaker ones. You need to adjust the antenna aim to favor it.
2) If I have the HD7698P antenna pointed at 263 degrees would I have to change direction to view stations that go to down 260 degrees and up to 270 degrees.
I doubt it; the beamwidth is narrow because of the high gain, but not that narrow. Take a look at the beamwidths here:
http://www.winegard.com/kbase/uploads/HD7698P.pdf
Keep in mind that the tvfool report is only a computer simulation, and is known to be less accurate for 2Edge signals.
