Old 13-Jan-2016, 8:40 PM   #20
Is the signal coming out of a 2-way splitter coming out of 1 output of the CM3412 weaker than the signal coming directly out of the other output of the CM3412? Is that how you are saying you could balance signal strength between TV with longer run vs TV with shorter run?
Sorry, I have confused you with too much information. That would only be for a 3-way split. For the 2-way split, both outputs of the 3412 are equal.
