Old 13-Jan-2016, 9:05 PM   #17
shoman94
That sounds correct. Try a Channel Master 3410 just before the splitter in the junction box. How many splits in the existing splitter? The 3410 has only one output, so an alternative would be a 3412 which is a distribution amp and a 2-way splitter combined.
If you need a 3-way split, you can use a 3412 and a 2-way splitter which would allow more signal to the longest run, and less to nearby TVs. If one of your TVs has a signal strength indicator, you can determine how strong a signal must be for reliable reception.
Or use an Antennas Direct CDA4 which has a 7.5db gain for each output. I've also use the RCA vh140R with great results and available right at Lowe's.
