If you want a smaller antenna, I'd have a look at the CS4V that includes the VHF antenna. Point it a approx. 260 degrees. That should give you Fox,NBC,CBS and ABC. CBS at 73 degrees and the other stations in that direction should be plenty strong enough to be picked up on the back side. I'm not sure you'll need a pre-amp. That will be trial and error.... maybe a powered splitter will be better. I haven't look at local FM towers in your area but you may need an FM filter.
I'm using this antenna to pick up a station with 2edge, 49miles away and an NM of 0.4...I'm getting a solid 60+% signal with it. I think this antenna needs more credit than its normally given.
